Grub54891
- Joined
- Jun 17, 2012
- 6,466
You might not see the crack as its inside the manifold. you can take the endcaps off and have a look, or do the acetone test, you fill the wet side with acetone and see if it leaks in to the intake side. Or I n your case since the wet side already leaks, fill the intake side and and see if it leaks to the wet side. I would do neither, as you already know it's cracked.
