eighty2scrambler
Thread starter- Joined
- Jul 5, 2008
- 16
Ok everyone I'm scratching my head big time. I'm going to attempt to explain my issues that I've been working through over the past few months. I have pictures to help explain.
A previous thread is here:
http://forums.iboats.com/mercruiser...-3l-exhaust-manifolds-intake-both-573310.html
Back in Late August 2012, i was on the lake all weekend with my 1998 CHapparal 18' 4.3L Merc with alpha one outdrive.
We had been skiing and wakeboarding all weekend long (3 days) and on Saturday the rain came. The boat stayed anchored in the water all day/night. It rained probably for 12 hours with large gusts of wind.... so much that it blew our campsite to shreds...(there is a reason I said that)
It literallly rained all day and night
The next day (sunday) I go out to check on the boat... obviously the entire inside is wet, but the Bilge pump held up good... no water in the bottom other than what was too low for the pump to get out. I fired it up and we went on a slow stroll around the lake.
After about a 10 minute boat ride I decided to Ski, As I am behind the boat skiing for about 15 seconds all of a sudden the boat loses power. Wife said she dont know what happened, So i crawl back in the boat and it fires right up. But doesn't idle good and doesn't have any power. trying to idle it higher and get it to "work itself out" it hydrolocks. (not knowing it was a hydrolock at the time). So I get towed back in.
I didn't mess with it at the lake that day, we packed up camp and drove the 4 hours home. The next week I try to turn it over with a loud familar hydrolock "CLUNK", I then found water in most all the cylinders (Starboard middle and port Middle being the most),
I took all the plugs out, and turned it over and over, lots of water cam eout of the cylinders... I put the plugs back in, and the boat fired right up and rand good.
I hooked water to it and it ran for abotu 10 -15 minutes no problem. Pulled plugs back out and they were pretty dry.
After doing research (see previous thread), I had thought that the water came from the Manifolds breaking down (1 piece merc manifolds that are 14 years old)..
I removed manifolds and tested them with hooking a garden hose to input and flushed water through it seeing none come through the exhaust...
Next I thought it could be the intake gasket leaking...(probably would have hydrolocked with the water running in the driveway again)
So far I've done a compression test (175-180lbs in all cylinders)
- tested manifolds
- checked intake gaskets (couldn't find any breakage or signs of a bad gasket)
Inside the intake LOTS of MIlky oil, Pulled valve cover gaskets, LOTS of milky oil (see pictures)
So now i'm thinking, Could that much water REALLY have "blown" in to the Carb and down the throat of the intake???
Surely not...
But where else could the water be coming from? A good compression test result should rule out Head Gaskets, or cracked block right?
The oil color on top of engine is a very milky color, I pulled the oil filter to find a darker, but milky color..
The DIPSTICK shows no signs of water in the oil. The oil is a very good color.
My thoughts are to put all new gaskets on, and put it back together and hope for the best. Can anyone shed any light on this issue??
A few things I noticed that bother me are:
Very Corroded water ports on the intake and the top of engine (see pics)
Some rust on starboard side exhaust ports (see pictures)
I went to local Merc store to buy more gaskets... the ones he gave me are a different material and differnt pattern than the ones that came off.. should these work? (see 2gaskets.jpg)
For those of you that actually read this whole thing and respond, I am forever grateful. I really am scratching my head.
If I am missing anythign obvious please let me know.
Thanks so much!
- tested manifolds
Surely not...
Thanks so much!
