WSchnellenberger
Thread starter- Joined
- Jul 17, 2017
- 1
I have a 1999 Mercruiser 3.0 L Compression on all 4 cylinders is between 160- 170 lbs. water in crankcase also. Changed oil, started engine on muffs. Ran at idle for 5 minutes saw water and oil coming from tube on pvc to carb. There was enough water to kill the engine. Boat has run fine all summer then all the sudden died running at 3200 rpms.
