Water Intake on Johnson 150
Patty1963
I have a Johnson 150hp and would like to know where the water intake is located to be able to try motor on dry land with water hose....
Chris1956
Re: Water Intake on Johnson 150
Patty, TD has the general answer for all the Johnnys build afte the sixties. Depending on the year of the motor there maybe otehr ways to flush. My '98 takes a hose up the telltale, as well as the muffs TD described.
tashasdaddy
very true, but if you run the motor, you better have the muffs on.
