water intrusion after gimble bearing replacement
rpatton
Mercy 120 Alfa drive 1986. After I replaced my gimble bearing I noticed water trickling in my transom around the water pump supply hose transom fitting. Any idea where this could be from the bellows are good.
Rick Stephens
Any where behind the gimbal can allow water in. The bellows, the bell housing gasket, the shift shaft seal, the o-ring for the water passage. All of them. Get water in one, get water in your bilge. Open it up and start looking and replace the gasket, o-ring and input shaft ring carefully.
rpatton
Thanks. You are correct. When I took it back apart I noticed the bell gasket was not where its soppesed to be. It had a blown in section about 3 inches long. Don't know how I did that but I did. Hopefully that's the issue. Just stinks cause that was a new bearing.
rpatton
Ok i replaced all the gaskets and seals and water is still streaming in around the water line on the transom plate. Enough to run my bildge every 5-10 minutes. Heres whats wierd that i noticed, it only comes in when someone is siting on the back to make it a little lower in the back. I looked and felt the bellows and felt no holes but it hard to tell but its gota be the bellows theres nothing else write? Are bellows hard to replace? I know theres special tools but which ones do i realy need and which ones can i make do without. Im very good with mechanics as in diesels and auto but only ever did the more non envasive repairs on the boat. I might add as far as i know the bellow where never changed. Please someone chime in thanks
sharkin95
bellows replacement is a pain first time I did mine took 6-8 hrs. now I do it in 3-4 hrs. The only special tools you need are a hinge pin tool to unscrew the side hinge pins that hold the bell housing and if you take off the exhaust bellows a bellows extender, one extremely important thing I can say is use the BELOWS ADHISIVE as directed there is a ton of info on this including you tube videos so TAKE YOUR TIME.My suggestion is if you change the universal bellows I would change the exhaust bellows also
rpatton
Thanks .the tool that take out the hinge pin to me on videos looks like a torx socket is that right. And what's so special about the exhaust bellows verses the ujoint bellow that you need a extender. Or is it a expander
