honda460ex
- Joined
- May 12, 2011
- 69
I have the gasket, but thanks to reading here have found out that the bolts are epoxied and need to be heated to remove and then some form of epoxy to reinstall... My symptoms are as follows. Motor acted up, lost rpms, and then once off plane wouldn't come back up on plane. NO POWER! Symptons got worse and worse until it would barely idle in the water. So I took it to a certified outboard mechanic (friend) and he looked at it. Thought I had a weak coil causing it to drop a cylinder. In the end I replaced pretty much every electrical component on the motor. Previous owner had a stator with one low rpm winding dead so he or someone else wired a jumper from power pack one to power pack two to make it run. So the motor was only running on half of the stator and the rectifier wiring was destroyed. Replaced trigger with the stator, new coils, wires, and one switchbox (I know, should replace both at once, but i didn't). Compression is good by the way. Have one cylinder down to 105 lbs, the rest are 125 lbs. Story on that, found piston #2 is missing its top compression ring. Thank God for two more rings! lol. When I set the timing step by step, on muffs it would fire and run at or above 1,200 rpms. As soon as you would try to bring it to an idle in would die like you turned the key off. Off muffs and out of the water it would fire and idle. I know not good for it, I didn't idle it longer than 5-6 seconds and I am replacing the impeller and housing with everything else right now too. Pulled the plugs and found water condensation on the bottom ones. Took the exhaust cover and such off and found a lot of milk... Pistons 5 and 6 look brand new. 4 is fairly clean. 3 has a decent amount of carbon. 1 and 2 have massive carbon build up. So I know I have a major water issue. I am pulling the powerhead and replacing the lower seals and I also have all gaskets for the top end that I am replacing. I want to fix it right the first time. So hence my initial question, with the water problem I am having, should I try to replace the inner water jacket cover gasket while I have everything else apart? Or do you think it is probably just the lower seals gone bad and I shouldn't fool with it?
Sorry so long...
Sorry so long...
