Water jacket gasket
Hennysemitara
I know on the head gasket it dont get gasket sealer, but the water jacket gasket does it get gasket sealer?
interalian
I use gasket sealer on any of the thin paper/card gaskets. Bypass covers, exhaust covers, top cooling cover, thermostat etc. etc. Paint it on the gasket thin, both sides.
Hennysemitara
Whats the torque spec for head cover and any bolt tightening pattern?
interalian
Cylinder head screws are 18-20 lb/ft. Water jacket screws on head are 60-80 lb/in. Torque in three steps to 1/3, 2/3 then full torque. Torque pattern - start in center and work out in increasing circles - applies to head and water cover.
Hennysemitara
how the heck are the water jacket gaskets so tight? those little bolts can handle? how about the lower unit oil, how tight do i make that screw?
interalian
The head bolts have 1/2" heads and go 18-20 lb/ft.
The water cover bolts have 7/16" heads and go 60-80 lb/inch (which is equal to 5-7 lb/ft).
