Water leak 4 hp
leor
I'm looking at a 1990 4 hp evinrude. On the side of the block by the starter recoil there is a flat plate held on by screws. Water leaks out of the joint between the plate and the block. If you rev the engine, it squirts out with a bit of pressure near the top.
Is this something that can be fixed with a gasket or does it indicate a major problem with the engine.
Thanks for the reply.
leor
Re: Water leak 4 hp
Thanks. I appreciate the reply.
