SeaRayboater95
Thread starter- Joined
- May 30, 2009
- 604
You guys have been very helpful in the past and I can't thank you enough!!!
1979 140 horse Mercruiser pre-alpha. I believe is the correct term.
The boat has been inside, warm, and not exposed to the cold all winter. I separated the upper and lower, changed the water pump put it all back together and installed it back on the boat. While trying to get it on the boat, water came out of a pinhole in the upper case as shown in the picture. I had not put water to the drive at this point. I thought this might just be a drain hole and didn't worry about it. I'm not sure why there would be water in it after sitting all winter and being apart. I'm wondering if this hole should be there and should there be water coming out of it. Thanks, Ken
P.S. I got it back together and running. Ran it through all the paces, on the muffs, and the gear oil was clean and didn't show any signs of water.
