Baylinercapri1987
- Joined
- Sep 7, 2006
- 198
Ok, I have posted before about this problem, And I am trying to tackle it again and need some info/help. When the boat is in the water, It leaks starboard side transom area. I cant really see in there good enough to locate it. It dribbles down above the lower shift cable and exhaust. Could it be the water inlet? Or the lower shift boot? Or something else? I am going to try and locate it in water with a camera but its pretty tight in there. It leaks about a gallon per hour and has not changed in flow, I have just been bilging it out. So where should I start? The water inlet looks a little corroded, I think I will start there, but it doesn't leak out of water when running the engine. Please help with a plan to find this problem. I have tried tightening the transom bolts, and the transom feels solid and not soft, and also 5200'ed the outer transom with no luck.
1987 OMC Cobra 2.3L
Thanks!
1987 OMC Cobra 2.3L
Thanks!
