I've got a water leak and need help diagnosing.
Motor is a 1996 Mariner 115 2 stroke.
Started the motor today for the first time this season after a winter of storage.
Motor started fine, idled fine, p'd water ok but I noticed a small water leak coming from the lower left corner of the motor. I took the engine cover off and determined the water to be coming from the lower left corner of the engine/cylinder head cover.
The leak is at the lower left corner of the cylinder head cover.
Questions I have are.... what is likely the cause of the leak? is it a simple gasket re and re? or could something be cracked? will the leak get larger/can I use the boat or should I fix it first?
Thanks for the help.
