Water leak
ronsbear
I have a small 15 foot boat with a outboard motor.The only place I can see a water opening is the drain plug. The Bilge hole is solid all around, with a bilge pump and i just installed a float switch because i'm going to put it in the water ( and leave it ) for the rest of season. Is there any other ways for water to get in sitting or crusing the lake. Thanks P S the drain plug is plastic with a rubbero ring and a plastic fitting in the back
Ayuh,...... Welcome Aboard,...... Rain,.....
Drain plug leaks
Crack in hull
Rain
Swamp the boat
Big wave
Anchor from the stern
Many ways for water to get in
