Water Leakage
Thomv
Can someone direct me to a writen procedure in replacing the bellows on my two Bravo One outdrives. I believe I am getting water into the hull from leaking bellows if that is at all possible?
Thanks
Don S
Re: Water Leakage
Pull the drive and look inside the bellows. If there is no water or indication water was in it (RUST) then that's not your problem.
Find the leak first so you are fixing the right problem
Could be the shift cable bellows, or even a rotted transom.
The service manual details how to replace the bellows. What year do you have?
Thomv
Re: Water Leakage
2003
