water leaking under carpet
american kids II
I have a Rinker Fiesta Vee 270 Cabin Cruiser. Boat is trailered right now for some small repairs and found my carpet wet inside cabin floor area. ?? what would be leaking under the floor/carpet.? HELP!
Augoose
Well....
More info is needed in order to help you. What type of cover do you have? Has it rained recently? Can you trace the source of water to a side or a corner of the deck? Where on the deck is it most wet? Are you absolutely sure the water is sourced from underneath vs having made it's way down and from somewhere above? How about some pictures?
crazy charlie
Water does not usually come from below.It is more likely running from upwards of your floor and down..get it water vacuumed up and dried out and monitor where it gets wet first because it will spread and seem like a huge leak .Charlie
Grub54891
How was it stored. If it was sitting bow down, Any rain that may get in the aft deck areas may run forward instead of going out the drainplug. Seen that happen quite often.
