Water leaking
daf64
Hello fellow boaters. I have a johnson 60 hp outboard. Year 2000 20" shaft.
I had to replace the water pump an thrrmostate, now I have a lot of water coming out top of exhaust housing. An do not know what i added a pic an circles were water is coming from . Fast you rev the motor the more that purs out .I have lots of water at the pee hole .
saltchuckmatt
Make a YouTube video so we can see what you see but it's probably all normal. Have you tested the overheat system?
daf64
I tryed to up load a pic .not working .never came out that area before I did the water pump . Is there an o ring on the drive shaft by the spines.
saltchuckmatt
It won't do pictures right now (technical issues) but you canale a video and post the link. Not that hard to do.
O ring is to keep water out of the end of the crankshaft.
Honorary Supreme Mariner
I doubt that a 2000 model uses an O-ring below the driveshaft splines.
