Hi all..just got a motor from a friend that I had to rebuild the lower unit. 70hp (1974) Johnson. I got it put back together, new oil seals, bearings, water pump, the hole nine yards. Installed lower unit, filled with oil, didn't do a pressure test cuz I have no means to do one. Anyway, hooked every thing back up, and it started fine, (after sitting in the weather for <br />three years!) Maybe this isn't a problem, but, water IS comming out of the holes in the lower case (fine), a little out of the exhaust relief holes (fine), and looks like a bunch? of water comming out ABOVE the lower unit by the upper exhaust housing. The book I have says, " this model features a "wet sleeve" exhaust system, consisting of an inner and and outer housing with a water chamber in between. The water discharged from the engine cooling system fills the space between the exhaust housings and maintains a specified level when the engine is running" Does this mean water should be coming out at that point? TIA.Dan
