Water Leaks
legalfee
I have a 1995 Force 90HP. When I cranked it up today I noticed water coming out of the bottom of the cowl assembly on both sides. Is this something I should be concerned about?
roscoe
yes.
pop off the cowl and see where it is coming from.
jerryjerry05
Yup like Roscoe said remove the cover and see if you can figure out where it's coming from.
The way the motors put together the exhaust/adaptor plate gasket might be the problem??
