Re: Water line on boat
Anything that will remove that brown stain is acid based, I am not sure where you are but here in S Ga in the salt marshes you can put your boat in Saturday morning and take it out on Monday and you have a very dark brown stain that does not come off easily, it will come off, I use either CLR or Whink, multiple aplications, rubber gloves, rag, soak rag in cleaner, apply, let sit, mist with hose after a couple minutes to keep moist, then rinse real good with hose and repeat process until it is all gone. My boat was in and out as mentioned above this past weekend and I spent about 2 hours removing the brown stain, I washed the boat time I pulled it out of the water and started the cleaning process. The acid has not hurt the gelcoat yet.
