water line stain removal
bubbajim
Anyone have any suggestions on what will clean the water line stain. I've tried everything I could get my hands on and thought I'd ask before I start wet sanding it.
thanks
Jim
Randy J
Re: water line stain removal
go to wally world and buy some lime remover in the soap dept, like they advertise on tv for cleaning showers put some in a bucket with soap and just wash and rinse like normal.. never sand paper on a boat hull unless doing body repair
reddogg
Have you tried a cleaner wax? That is wax with a bit of rubbing compound in it, 3m makes some nice stuff.
Red
2000fourwinns
On Off Hull cleaner. I bought some from West Marine to clean my hull from sitting in the water for months. They make it in gel form and liquid. I used the gel form because it was so bad. It wiped off the water stain without any effort.
Thalasso
MaryKate cleaner. Wipe on wipe off. You can't use it on Aluminum.
Home Cookin'
What he said. Get the industrial stuff. You won't believe how clean it gets the hull without any effort. No affect to the gelcoat or fiberglass.
however, it stains a galvanized trailer so keep it hosed off
bubbajim
Excellent...I'm going to try this today. Many thanks
airdvr1227
Look at the ingredients. Need to find a cleaner that has oxalic acid.
crazy charlie
Let us know what works for you.Very important when you are finished removing the stain.Wax over the area or the stain will com,e back faster than ever.The gelcoat needs to be sealed by the wax.A water line stain is organic.It is actually alive and grows/spreads.After I wax the cleaned area,I usually leave a thin coating of wax at the water line which will wear away in a few weeks and prevent a new stain.Charlie
whitecrystal1
Slimy Grimy! Use Toilet Bowl cleaner on toilets lol j/k :p Anyways, Slimy Grimy cleans aluminium too so no worry about the trailer if it is aluminum. This stuff works great and I was happy with the results the first time I used it... no elbow grease needed ;)
http://www.youtube.com/watch?v=BqK1x6BSB1c
JASinIL2006
After cleaning it (and protecting the hull with a sealer or wax) the easiest thing to do is to have a couple of wet rags handy after you pull your boat. In 5 minutes you can wipe down the hull and avoid this in the future. I get this on my boat, and it's MUCH easier to wipe off right after you exit the water.
Jim
Woodonglass
Honorary Supreme Mariner
Uhmmm, this thread is 2 years old!!!!!
