Water mixing w/ oil in lower foot.
IPA006
I've spent the past several weeks clean carbs and replacing the impeller. I took the boat for a run last Tuesday, and it ran good. I was to put the boat in the water on Sat. but when I lowered the engine to start the motor on the muffs, a white milky fluid was running out the engine. I ckecked the oil in the lower foot and it was milky white, obviously water is mixing with the oil. Can someone please recommend where I should start to begin fixing this problem.
Thanx,
sc gator.
