water out the exhaust
celtic gelf
how much water is normal to be coming out of the exhaust tube.....I noticed a huge difference from a few weks ago...mind you I did have a bad impellor that led to a mess...i'm going to install a pisser I found plug but it's a slotted screw and was more then hand. I stopped playing with it in fear of stripping it slot...I'm thinking impact screwdriver with a tight fitting straight blade?? Yes or no?
fucawi
Banned
Re: water out the exhaust
without a photo who knows ..tried heating it ...??/
tater76
Impact with straight blade will work, but it is very likely corroded in place. I have never been lucky enough on any of my motors to get it out easily. If it absolutely won't come out you will have to drill it using a kobalt bit. Your plug is stainless steel right? Maybe you will get lucky and its brass or plastic, those are easy :)
celtic gelf
the bolt seems to be stainless i'll play with it some this week thank you..I can't get photos off my blackberry to post em not sure why....
