When on the trailer- always park it bow high. In the event that water gets into the boat you want it to drain down and get out.... should the boats bow be higher then the stern or should the boat be level when you have covered?
And you should always keep your outdrive trimmed down as far as you can when storing the boat as well. The bellows will last longer. When the drive is up, it keeps undue tension on those bellows.
Also, never run your engine when the drive is trimmed all the way up in trailer position. It's bad for the u-joints.
So, which are the 7 loops you ignore?I called Carver and they said 12 straps should be enough!
