Water Pressure gauge installation, need a little help!
Gbakman53
I have ordered a complete kit with gauge. It is a Sierra International product. I have also researched how to install it and the instructions on it say to tap into the cylinder head. The engine block has a dedicated port specifically designed for reading cooling system pressure.
It says to locate, look on the starboard side of the engine block/cylinder head. Just near the middle spark plug, you will see a 7/16” brass hex-head pipe plug. Remove the plug and thread in a hose barb or compression adapter from your gauge kit. Well, I have looked several times and I am not seeing a brass hex-head plug or anything other than the head bolts. Can someone explain where they might have found this hex-head plug? I appreciate any honest feedback! Thanks
Chris1956
Honorary Supreme Mariner
Gee, what motor are we talking about. My 60* V6 had such a port on the port head. It was easy to find. Not all motors will have one, I would guess.
Agreed, what motor?
also, Sierra just packages the gauges. they are made by VeeThree in Bradenton Florida
jimmbo
I suspect the Instructions are referring to a Mercury, as they almost always had a Place, with a Brass Plug where a Pressure Gauge Hose/Tube could be fitted
Gbakman53
Well, I got the gauge and the hardware. After looking at the motor again! I saw the outlet that the pee hose is connected to and they provided a brass tee fitting and two barbed fittings so I just replaced the barbed fittings that the pee hose was connected to with the tee fitting and the 2 barbed fittings and attached the hoses and got it all done. Thanks
Chris1956
Now you get to see if it works well. Sometimes the telltale outlets do not have any pressure.
