Re: water pressure gauge
The tube is generally filled with air.<br />Water in the engine pushes on the air in the tube, which activates the guage.<br /><br />If you are concerned about water/freeze damage in the guage, just disconnect the guage end and blow some air thru the tube to expell the water. Don't forget to re-attach, or you will pump water into the boat the next time you start it.
