Water pressure gauge
realmasa
Hi,<br /><br />i'm planning to buy a water pressure gauge, either Teleflex or Faria. These are sold as a "kit", does this include everything? Sender, wiring etc? Like this one here e.g. Nothing is found under "accessories". I need some help here, i don't know what's needed except for the gauge itself. I have a Yamaha HPDI 200hp -01.<br /><br />/Mattias
ricksrster
Re: Water pressure gauge
I bought a Teleflex. Included in the kit were instructions, fittings for most applications, and tubing. The wire wasn't included. The only wiring on the gauge was for back lighting and I wired it to the lighting wires behind the dash.
realmasa
Thank you Rick,<br />I assume Faria has that included in their "kit", it wouldn't be a kit else.. :)
carljh
I bought a Teleflex for a Yamaha and I also had to purchase an adapter for the connection to the engine, can't comment on the Faria.
realmasa
Hmm.. i just ordered teleflex outboard 30psi kit at cabelas.com, this one, and i can't find any adapters on their site.
Silvertip
Any adapters (brass pipe nipples, tees, barbed fittings, couplings etc.,) are available at any home center or hardware store. Use bushings to upsize or downsize connections to the engine.
roscoe
you are going to need a hole saw to drill the hole in the dash, can get at any hardware store.
Silvertip
Here is how I did mine on a 75 HP Merc. The large line is the tell-tale. The black plastic fitting was originally screwed into the engine. A short brass nipple replaced that fitting. The brass "T" screwed onto the nipple, and the original elbow and another brass elbow completed the plumbing. The small tube runs to the gauge. I think everything was included with the gague except for the brass elbow and maybe the nipple. With a new impeller the gauge reads 7 PSI @ idle and 17 PSI @ WOT).
realmasa
Thank you Upinsmoke for the pic, do you ever experience pressure drops when trim up your engine?
rodbolt
why not buy the yamaha kit that contains all the nessasary fittings,tubing and guage as well as installation instructions ?
realmasa
Hi Rodbolt,<br />i will tell you why; Yamaha gauge + wp sender and tubing 175euro.<br />Teleflex gauge kit with tubing wp sender 35euro.
Silvertip
As for loss of water pressure when trimmed -- I don't have that problem. My boat has Smart Tabs so the engine can do its job of pushing the boat without being trimmed up a great deal.
