Re: Water Pressure Gauge?
First thing you have to do is check that the line is clear from the engine fitting to the gauge - without any kinks, twists, or pressure spots. I think I checked mine three times before I found the little kink/twist that was causing the problem. Also, could be clogged at the engine fitting or anywhere along the way. If this isn't helping, take another piece of tubing (equivalent tubing is available for very cheap anywhere hose and tubing is sold) and connect the gauge directly from the motor to the gauge without running it through wherever the final installation is. This will make sure there's no hidden problems. You can also take the gauge out of the dash and hook it directly to the engine fitting with a short piece of tubing. <br /><br />As for the readings, there should be a spec for your engine. I found the spec for mine at the teleflex website under tech support. (there's a long list for various engines). For a new-ish engine like yours, I'd think the dealer's shop would have a spec for that. Good luck.
