water pump 1989 90 johnson
johnson89
teying too do a water pump change but stuck on trying too get the link rod off. I pulled the bottom carb. but still can not see how too disconnect the linkage, the only screw I see is turned around backwards an screws out towards the power head,is there something I am not seeing.I have done a water pump in the past(about 15 years ago )an that 1 had a cotter pin you pulled out.Yes I know i need too get a book but money is real tight right now, just got back too work a little while back. Thanks for any help
tashasdaddy
Re: water pump 1989 90 johnson
on that motor or the starboard side, shift lever, where it turns to go under the motor, is a snap type cotter pin. pull the pin, then push the rod toward the port side. do not turn the shift rod while the lower is off.
johnson89
ok,yes I saw that pin your talking about... thanks for the info
