water pump 35 hp
pikefisherman
maybe need to repost this but how much water should be coming out of the back just a spurt or a lot.35 Forse
jerryjerry05
Re: water pump 35 hp
Most water will exit through the snout on the lower unit.
The 50/35/25 needs a special muff.
The ones used on the bigger motors work, but can actually cause it to overheat.
You should get some water out the mid section.
Maybe just a mist or even steam?
