Re: Water pump- Clinton K700 1973?
I just did this one, it's easy! Just remove the lower unit: should be 2 bolts. A flat head screw just north of the prop, then remove a little clip on the front(same heightas the flathead)and you'll find a nut underneath. the impellor is on the prop shaft in a little housing.
