Water pump- Clinton K700 1973?
Michael 1
I have a Montgomery Wards, Clinton, Model K700 1107 A Ser 444682
Type 60 27270 R. Does this have a water pump for the exhaust to cool lower unit? Or any type of water pump? If so how is the best way to remove the impeller? Thank You.
xltom
Re: Water pump- Clinton K700 1973?
I just did this one, it's easy! Just remove the lower unit: should be 2 bolts. A flat head screw just north of the prop, then remove a little clip on the front(same heightas the flathead)and you'll find a nut underneath. the impellor is on the prop shaft in a little housing.
