samhoustonkurt
Thread starter- Joined
- Jun 12, 2022
- 3
Hello.
I have 1986 Force 4hp outboard model 42F6A. I pulled the lower unit to check the water pump because it was not peeing (that I could see) when I ran it at idle in a bucket.
I inadvertently pulled the drive shaft out of the lower gear housing and the gear below fell out of alignment. Through lots of shaking the lower unit, I was able to get the gear to where I could get the shaft back through the gear but now I just have one gear (not sure if it’s forward or reverse) so obviously things have come apart badly.
Anyway, I am resigned to the fact that the lower unit will need to come apart and be correctly re-assembled, but I don’t want to hose that part up too.
Does anyone have the specifics procedure for dis-assembling and re-assembling the lower unit? Also, the procedure for replacing the water pump would be helpful to keep me out of trouble next time! Not finding a lot on YouTube that is helpful.
Thanks!
Thanks!
