Water Pump Help '89 85HP
LukeB777
Took the lower unit off to cahnge the water pump and while removing the screws to remove the plastic housing one of the nuts just spins the bolt (Like I need a wrench on the bolt too). But it appears that there is no place to hold the bolt to remove the nut. Any tips or tricks??
Frank Acampora
Re: Water Pump Help '89 85HP
Sounds like a dual exhaust lower unit with a Merc designed pump. Four studs are screwed into the casting with four top nuts. Unscrew the whole stud, nut and all then remove the nut with the stud in a vise. If it just spins without coming out, it is stripped and you must apply upward pressure while unscrewing.
