riverdog01
Thread starter- Joined
- Apr 21, 2010
- 48
I dropped the lower unit today in 1985 8 HP evinrude to replace the water pump. The screws were easy to remove and when I lifted the water pump housing up all that was left was pieces of the rubber.
The old impeller pieces fell off what looks like a nut on the drive shaft but the new impeller for this model is setup with for a key. The shaft move easily up and down feels like it would come right out. The manual I'm looking at says I'm supposed to lift the impeller off the shaft and leave the shaft in place but it almost looks like I have to take the shaft out to get this off.
Should I lift the shaft out to get this off ? Do I have the wrong type of water pump kit and impeller. Hopefully the pictures will help.
Thanks for your help.
What's left
New Impeller
What's left
New Impeller
