Hey guys. I'll give you a quick background to my problem here.
I am replacing the 4.3 block in an 88 Thundercraft. The previous owner made the fatal non-winterizing mistake of not draining the block, and, well.... you know the rest
So I was able to get a very cheap block from a 97 Astro van. I stripped it bare and prepped it, reconditioned the rotating assembly from the original Merc. 4.3, and started to transfer everything into the donor block along with new Merc bearings, pistons and rings. All went very well.
The only small snags I had encountered until last night were the fact that the oil pan and timing covers are different on the newer block and I had to use those from the newer truck application instead. Not a big deal.
However, once almost all back together last night, I went to put the water pump on the front and hit a bigger snag. The newer composite timing cover has a different contour and sticks out further than the original steel cover, so now my water pump wont mount. On the starboard side, the pump outlet hits up against one of the cover bolts and is about 1/2" away from seating on the block.
My current solution to this is to make 2 spacers (one for each side) to space out the pump equally and pull it away from the cover to clear. However, then my belts will not line up, so I will have to also make spacers for the crank pulley and the altenator and power steering pumps.
Can anyone else think of another solution. Is there possibly a different water pump from a newer application that is made to clear the composite 1996 - 2000 timing covers that I could use?
Any help or suggestions would be appreciated guys.
Thanks.
Thanks.
