water pump hose
rubaggd
how can i change the water pump hose from the outdrive that connects to the back of the boat above the exhaust bellows? can this be done without taking the outdrive off? i may have confused yall but im new with this boat lingo stuff. the hose has a hole in the bottom of it. i can get to one of the hose clamps at the outdrive but where it connects above the exhaust up in the top it looks very hard to get too without dropping the outdrive
Re: water pump hose
Ayuh,... Generally speakin,.. Nope, No way in 'ell...
If that hose is rotten,.. The Bellows are too...
That's why they're All changed at the same time,...
Not only the Drive, but the Gimbel needs to be pulled...
ziggy
Re: water pump hose
+, even with the drive and bell housing out of the way. that hose is still miserable to R&R imho...
bigskiohio
Master Chief Petty Officer
Re: water pump hose
and it has to be the right length or i will pinch .
