terrysandlin
Thread starter- Joined
- Jul 26, 2012
- 67
Removal of the water pump housing on my 9.5 Evinrude (the motor had set unused for 5 - 10 years) revealed that the housing cup had small pits in it. This was after removing impeller crud in the cup with a wire brush using a Dremel tool. The small pits were on the top of the cup and the sides.
Do I need to replace the housing? Will the small pits abrade the impeller so that I need to replace the impeller more often than once a year? If I need a new water pump housing, where can I get one. Many of the sites referred to in this forum do not show a water pump housing for a 9.5 1964 Evinrude/Johnson. I already have a water pump repair kit.
Thanks for all you help.
Terry Sandlin
Topeka, KS
Terry Sandlin
Topeka, KS
