Water pump housing removal for 1969 Merc 500...
michaud500
I have a 1969 Mercury 500, serial #2629264. I can't get the lower housing of the water pump out of the lower unit. What is the trick getting it out? I have done it before but can't remember how to remove it. The vent plug has been removed.
GA_Boater
The vent screw won't help. Did you take out the flush port screw?
GA_Boater
Then gently pry on the bottom pump base. There isn't much get a grip on, but I pried at the gasket joint on the front and back, then leveraged the base up.
Some pump bases have a threaded hole for 10-24 screw to thread in and break the gasket joint.
