water pump impeller
Tom Glandon
I have a 1994 mercury 40 horse 4 cylinder out board, i pulled the lower unit off today and there is no impeller, i cant find anything that looks like an impeller, please help.
snapperbait
Re: water pump impeller
Did you remove the waterpump housing? <br /><br />Should be a plastic housing with four bolts that slides down over the driveshaft.
Elmer Fudge
The impeller could've possibly disintergrated, poke around the water passages and retrive all the broken pieces you can find.
