Jhawk090108
- Joined
- Jan 17, 2014
- 9
Not too long ago I posted about my 25 Nissan fouling plugs. I have changed the plugs to the suggested p type plugs but have not had a chance to run them yet. After changing them I started the motor in a barrel and let idle for a few minutes. The motor never did start peeing. I pulled the water pump and it looks to be in pretty good shape and my local mechanic agreed that that was probably not my problem. I blew air back through the hole while the lower unit was off just in case of obstruction and put it back together. Still not peeing. I pulled thermostat And stared engine and there is no water mAking it to the thermostat.
Any advice on where to look next would be great. On a tight budget and can't afford to get this thing worked on right now. Crappie will be biting soon!
thanks
thanks
