Water Pump Leaking
Thomv
On my starboard engine the raw water pump is leaking between the pulley and the housing on my 1999 454 big block. After struggling for over an hour I was finally able to remove it from the boat. Can't understand why a boat manufacturer would design the back seat to be within an inch or two of the front of the motors. To actually get at the pump I ended up having to remove the main water pump hose, the alternator and the bracket holding the alternator to the block. Very difficult job getting at this pump. I have not had a chance to tear down the pump to see why the water is coming out of the front of the housing. All I know is that while out on the t water the pump was doing a fine job spraying both motors with salt water.I guess I can expect issues with a boat that just turned 15 years old. For about $300 I can pick up a new OEM pump complete.I will also replace both thermostats because both motors are running 180-200 degrees at cruising speed of around 48 MPH.
