bryanwess2000
Thread starter- Joined
- Jul 16, 2008
- 240
I recently installed a waterpump repair kit on my 1977 850 merc. and it stops
pumping water and starts blowing steam out of the telltale after about 5-10 secs once the boats on plane. I then throttle back and come off plane and the telltale resumes spraying water after about 5secs. Any help would be appreciated. the boat is a 1986 glasstream 1550 pro bass. The prop shaft is
8-9 inches below pad so it should be picking up plenty of water. A couple of things that come to mind are that I ground off a tab that was sticking out on the inside of the water pump insert and that I installed a different prop on the engine. thanks for the help!
