shackle101
- Joined
- Jan 11, 2012
- 140
Hey guys so replaced the water pump on my alpha one gen 2, and now when putting my boat in forward or reverse it seems more difficult. Also in forward it's making a loud clicking noise. I suspect something isn't seated correctly as I only took the foot off. When you guys service these do you take the upper unit off as well? (I'm used to outboards). I'm really hoping this didn't damage the spines or something is that likely? At this point I feel like I'll need to drain the oil and take it off with the upper unit and try to get it seated better. Any other suggestions?
I did test it with only 4 of those main bolts in but they are tight and I see no gaps at all between the lower and upper unit. Maybe I need to add the anode, and back bolt? I doubt that would change much. Good news is the pump seems to be working fine at least.
