CorvetteOnWater
- Joined
- Apr 19, 2009
- 13
In the process of changing the water pump assembly on an Alpha 1 ist gen.
Couple questions, the water pump kit cam with more o-rings and gaskets than I removed from the set up. What are these for?
Second the impeller is larger than the pump housing is that the way it supposed to be? basically wedged in there curved after turning the shaft?
Plus how do you pressure test the system?
