Working on a few things trying to get my boat running correctly. Today I installed (tried to install) a new water pump kit for a 1991 150 Black MAX.
When I took the old unit out there was not a O-ring, "slinger" or sealing gasket on the driveshaft. Looking in the service manual, the closet water pump picture they show to mine is the 40hp, 50hp, and 60hp "high pressure pump."
As you see in the pik there is a seal.
When I look to the 150hp model in the manual it shows an O-Ring....however my pump did not look like what the book shows.
Lastly, when I look it up on Mercury parts it shows an O-ring (item 36) but says as a side note "If applicable."
Advice??? Leave with no seal...throw in the o-ring or the larger rubber seal that I got in the kit....trying to avoid getting stranded on the water for a third time.
Thanks!!!
Thanks!!!
