Tim Frank
- Joined
- Jul 29, 2008
- 5,354
Re: Water pump snafoo!!
^^^ +1.
Called plug tap or bottoming tap.
I've had mixed results with easy-outs. You can try using one, you need to have patience while using it. Most of the time when I've used them, if the bolts really locked into place, the easy-out will become overwhelmed and just open up the hole you drilled in the broken bolt.
^^^ +1.
Like others have suggested, re-tap the threads when your done. You need a tap for a blind hole which will get the threads all the way at the bottom.
So are most easyouts...that's why they snap and are so tough to drill out afterwards.I would suggest using some white lithium grease on the tap flutes to both lubricate the tap and collect any metal shavings made by cleaning the threads. You want to twist the tap in a couple turns at a time, then back it out. DO NOT force the tap or you will easily break it off. It is hardened steel, so it is brittle.
