water pump troubles
jeff13601
Re: water pump troubles
Look for anything that may be plugging the water flow. You could have bad seals, o rings or a bad pump case. In your first post you said no water was coming from the hole, what hole? Is the water hose going from the transom to the t- housing clear. If you have it apart you prob should change it. Looking good does not mean it is ok. Something isnt pumping water
jeff13601
Take out the screw on the water intakes where you put the muffs and see if there is seaweed or anything else in there preventing water from going in
Reel Poor
now I really dont know what to look for as to why it is not pumping water out of the peehole.
Mercruiser Drive.....?<br /><br />What peehole??
dsims
The hole on the bottom of the drive. I had another mercruiser 120 just like it and it had a steady stream of water that comes out the bottom.
jeff13601
After you check for blockages, put it back together. Hook up the muffs and unhook the long water line from the transom to the T-stat housing at the t stat housing and see if you are getting water to that point
dsims
Ok checked for blockages by backflushing it and water come out the tube that goes down to lower foot so no blockages. I will check that this weekend Jeff.
dsims
Got an update. I let my friend who knows about boats at work pull the water pump apart and what I thought was a normal looking impellar was not right. The minute he pulled it out he said it was messed up. The arms were not straight and went out and made curves pretty bad at the ends. I looked at the normal impellars on iboats parts and mine looks like octopuss arms. So Monday I will go get a new impellar and that should fix it. One final question, does my mercruiser 120 1986 motor have a water pump on the engine also? I dont think so but want to make sure.
jeff13601
Yes. In the front above the crank pulley I believe
