Re: Water pump/ water in lower unit
only if the seal on the base plate ( O Ring ) is bad or the shaft seal on the baseplate. this is the bottom half of the waterpump an not easily removed I used 3 inch screws and a pry bar to get mine out be careful not to go to deep and score the casing. Pull the stainless pins and scre into the holes and use the "top" of the LU bolt for leverage
