fishingtomatoseed
- Joined
- Apr 22, 2003
- 38
I have a 1991 Mariner 150 mag. 2 ser#0D007551. I replaced the water pump in it this weekend. The reason is that it was only running about 2psi. @ ideling and 8psi @WOT. Now it is about 7psi and 12psi. But at ideling it shows 5psi on the gauge but there is none coming out the p hole. it only comes out when you idel it up to about 1000rpm's. I have looked at the lines to make sure that it is not clogged up and it is not. Is this normal or sould there always be water coming out the p hole.
