water pump
robertmcp72
on my 1994 150 hp force i discovered an oil leak<br />the bottom plate on the waterpump has a small crack. that plate is fairly expensive.<br />is there any kind of epoxy that i can use .<br />or should i get off my wallet.
johnnyg531
Re: water pump
JB Weld makes a 2 part epoxy that I've had good luck using. They make one for Aluminum also one for Steel
