water pump
TPD
hi guy.
i just recently bought a 14.5' fiberglass caribean with an old johnson 60 hp V4motor off a mate. and was wonder if there was any way of telling if it pumping enough water, it spray a small amount out of the rear pipe. my mate wasn't sure either.
the motor been well looked after, run greats
any infomation or a link to an exist post would be great.
thanks Tim
tmcalavy
Re: water pump
We need to know the model and year to tell you where to look to check the water pump. An OMC/Johnson should have the model/serial number on a metal plate at the top of the transom clamp, just under the front of the motor cowl/cover.
TPD
Re: water pump
Thanks
I'll have a look when i get home at the end of the week and get back to you.
Thanks again
